Hi Mike,
Yes usually there is a "for" loop at the end of your main function. The loop has a set of curly brackets after it. Everything in the curly brackets gets executed every time around the loop. So if there is N operations that you want to have continuously performed then put them all in the loop.
Yes the Green Bar on a Thread indicates that Thread is current executing a program.
Message: 5008 |
Date: 5/20/2012 |
Subject: Re: SnapAmp .....No More Function |
I thought I read somewhere (although I can't find it again) that the dc supply for the SnapAmp should be turned on after the axis' have been enabled.
Is that correct?
Must I enable the SnapAmp fans manually, or do they come on at a specified temp?
I saw the fan on c program in the folder, and wondered.
Mike
> Hi Mike,
> From: michaelthomasn <michaelniksch@...>
> Sent: Friday, May 18, 2012 2:38 PM
> Subject: [DynoMotion] Re: SnapAmp .....No More Function
> Ok...thanks again.
> I just bought an Arduino for me and my daughter to fool around with. It looks like the programming language is similar to C. It will help to learn on, anyway.
> I should have gotten one first...lol.
> If I run a second watchdog....do I need to place it between the brackets of the first one (watchdog) at the end of my init.c?
> Does the green box that appears around the thread number when I run a program with a watchdog just mean something is ongoing?
> Mike
> > Hi Mike,
> > ÃÂ
> > For the opto inputs the 470 ohms is internal.ÃÂ Just connect the + terminal to either +5V or +12V and the - terminal to your switch and the other end of the switch to ground.
> > ÃÂ
> > Regarding not being messy: That is hard.ÃÂ The Winford board has a prototype area you might consider using.ÃÂ Otherwise you might find industrial PLC or OPTO22 type modules to do the conversion.ÃÂ But you still may need a serie resistor if they put out +5V (or actually more thanÃÂ 3.5V).
> > ÃÂ
> > From: michaelthomasn <michaelniksch@>
> > Sent: Friday, May 18, 2012 7:34 AM
> > ÃÂ
> > Tom,
> > Aah....Thanks very much for that drawing. I can't seem to understand these things without one, yet.
> > I'm wondering how to add these components without making a mess of my wiring and having things running everywhere.....lol.
> > Would you happen to have a picture of someone's clean wiring job that might show the external add ons like the resistor and capacitor?
> > I have the winford BOB's for the SnapAmp, and JP7 on Kflop.
> > I see in the manual that the opto input circuit shows a 470 ohm resistor on the opto+ pin.
> > Is that internal, or a suggestion?
> > My boards are on their way back to you....and I forgot to put a note in the box explaining the trouble.
> > Thanks again,
> > Mike
> > > Hi Mike,
> > > ÃâÃÂ
> > > I'm not sure I follow that.ÃâàBut see attached for a possible solution.ÃâàThis takes advantage of the internal pull downs on certain KFLOP pins.ÃâàThe Pull up forms a divider to put 3V on the pin.ÃâàWhen the switch opens R2 pulls the pin to 0V.ÃâàR1 also provides protection against spikes on the +5V bus.ÃâàThe capacitor provides filtering in case of nois spikes picked up in the wiring.ÃâàTo use Pins without internal pull downs add a pull down externally.
> > > ÃâÃÂ
> > > Regards
> > > Sent: Thursday, May 17, 2012 7:09 AM
> > > ÃâÃÂ
> > > Tom,
> > > Well.....OK, I actually don't understand. You mentioned using a resistor of a few hundred ohms in series on the power side of the pulldown circuit in case of voltage spikes.
> > > Wouldn't it be prudent to do a similar thing on a pullup?
> > > I guess you would put the 200ohm first, then the 1kohm to ground and take the power from between them to the input pin? The switch would then be between the resistors to ground.
> > > In the above scenario on the pullup, though, the circuit would be consuming some current in both states?
> > > I'm sure I'm missing something here (probably a lot :-)).
> > > Mike
> > > --- In DynoMotion@yahoogroups.com, "michaelthomasn" <michaelniksch@> wrote:
> > > > Tom,
> > > > You mentioned a 1k pullup in another discussion we had....what value pulldown would I need?
> > > > It seem like a safe pulldown circuit is a little more complicated (with the extra resistor) than a good pullup. I suppose I should just use a pullup and change the state that I am looking for in the watchdog.
> > > > Mike
> > > > --- In DynoMotion@yahoogroups.com, Michael Niksch <michaelniksch@> wrote:
> > > > > Thanks
> > > > > On May 16, 2012, at 6:59 PM, Tom Kerekes <tk@> wrote:
> > > > > > Looks reasonable to me.
> > > > > > TK
> > > > > > Sent: Wednesday, May 16, 2012 5:35 PM
> > > > > > Well....that actually makes sense to me.
> > > > > > I can safely say that it would not have last week....lol.
> > > > > > Would you mind looking at this watchdog addition in my init and tell me if it would even work. I never got far enough to test it. The plan is to have it in tandem with my hardware estop that drops the contactor to my amp PS. Maybe I don't even need it? I'm learning slowly.
> > > > > > http://tech.groups.yahoo.com/group/DynoMotion/files/michaelthomas/
> > > > > > Thanks,
> > > > > > Mike
> > > > > > > Hi Mike,
> > > > > > > ÃÆ'Ã'âââ¬Ã
> > > > > > > +12V is not required for KFLOP/SnapAmp.ÃÆ'Ã'âââ¬Ã
¡ That supply is just routed through KFLOP to the various connectors to be convieniently available if needed for some custom purpose.
> > > > > > > ÃÆ'Ã'âââ¬Ã
> > > > > > > SnapAmp GPIO inputs are +5VÃÆ'Ã'âââ¬Ã
¡ tolerant so connecting directly to +3.3V should not be a problem.ÃÆ'Ã'âââ¬Ã
¡ But it would be prudent to add a series resistor of several hundred ohms.ÃÆ'Ã'âââ¬Ã
¡ It that case if there was a momentary noise spike to say +7V ( or -2V) it wouldn't cause any damage.ÃÆ'Ã'âââ¬Ã
¡ The GPIO inputs are very high impedence (meg ohms) so a series resistance would still easily drive them.ÃÆ'Ã'âââ¬Ã
> > > > > > > ÃÆ'Ã'âââ¬Ã
> > > > > > > However you would also need a pull down resistor.ÃÆ'Ã'âââ¬Ã
¡ This is because when your switch opens the input would be left floating and would not necessarily return to 0V.ÃÆ'Ã'âââ¬Ã
¡ More likely stray capacitance would keep it at 3.3V so the signal would remain high whether the switch was open or closed.
> > > > > > > ÃÆ'Ã'âââ¬Ã
> > > > > > > You might also consider using the SnapAmp Opto Isolate inputs if there are any remaining.
> > > > > > > ÃÆ'Ã'âââ¬Ã
> > > > > > > Regards
> > > > > > > TK
> > > > > > > ÃÆ'Ã'âââ¬Ã
> > > > > > > Sent: Wednesday, May 16, 2012 4:43 PM
> > > > > > > ÃÆ'Ã'âââ¬Ã
> > > > > > > Yes....I have 5v and 12v.
> > > > > > > Assuming I actually connected the switch to 3.3v (and not 12, which it seems I must have)....is that the proper way to send the pin to a high state?
> > > > > > > I did not have a resistor in series with the switch.....as I didn't think it would be necessary.
> > > > > > > Mike
> > > > > > > > Hi Michael,
> > > > > > > > ÃÆ'Ã'Ãâ 'ÃÆ'ââââ¬Å¡Ã¬Ãâ¦Ã¡ÃÆ'Ã'âââ¬Ã
> > > > > > > > 3.3V shouldÃÆ'Ã'Ãâ 'ÃÆ'ââââ¬Å¡Ã¬Ãâ¦Ã¡ÃÆ'Ã'âââ¬Ã
¡ not cause any damage.ÃÆ'Ã'Ãâ 'ÃÆ'ââââ¬Å¡Ã¬Ãâ¦Ã¡ÃÆ'Ã'âââ¬Ã
¡ TheÃÆ'Ã'Ãâ 'ÃÆ'ââââ¬Å¡Ã¬Ãâ¦Ã¡ÃÆ'Ã'âââ¬Ã
¡ next pin over on JP7 is 12V though whichÃÆ'Ã'Ãâ 'ÃÆ'ââââ¬Å¡Ã¬Ãâ¦Ã¡ÃÆ'Ã'âââ¬Ã
¡ wouldÃÆ'Ã'Ãâ 'ÃÆ'ââââ¬Å¡Ã¬Ãâ¦Ã¡ÃÆ'Ã'âââ¬Ã
¡ cause damage.ÃÆ'Ã'Ãâ 'ÃÆ'ââââ¬Å¡Ã¬Ãâ¦Ã¡ÃÆ'Ã'âââ¬Ã
¡ Are you applying 12V to KFLOP?
> > > > > > > > send to:
> > > > > > > > Dynomotion
> > > > > > > > c/o Tom Kerekes RMA#23
> > > > > > > > 3532 Adamsville Ave
> > > > > > > > Calabasas, CA 91302
> > > > > > > > TK
¡ ÃÆ'Ã'Ãâ 'ÃÆ'ââââ¬Å¡Ã¬Ãâ¦Ã¡ÃÆ'Ã'âââ¬Ã
> > > > > > > > Sent: Wednesday, May 16, 2012 4:20 PM
> > > > > > > > I connected a NO pushbutton switch wired to 3.3v from pin 1 on Kflop JP7. I never quite got it hooked up before the lights went out.
> > > > > > > > There are no lights on the SnapAmp at all. Was that a stupid thing to do?
> > > > > > > > I obviously made a mistake....lol.
> > > > > > > > Do I send it to the address that it came from?
> > > > > > > > Mike
> > > > > > > > > Hi Michael,
> > > > > > > > > ÃÆ'Ã'Ãâ 'ÃÆ'ââ¬Â 'ÃÆ'Ã'ÃââÃÆ'ââââ¬Ã
¡ÃâìÃÆ'ââ¬Â¦ÃâáÃÆ'Ã'Ãâ 'ÃÆ'ââââ¬Å¡Ã¬Ãâ¦Ã¡ÃÆ'Ã'âââ¬Ã
> > > > > > > > > What did you connect to pin 83?
> > > > > > > > > To Test you should remove all connections from both boards.ÃÆ'Ã'Ãâ 'ÃÆ'ââ¬Â 'ÃÆ'Ã'ÃââÃÆ'ââââ¬Ã
¡ Leave only the 16 pin ribbon connection between KFLOP and the SnapAmp.ÃÆ'Ã'Ãâ 'ÃÆ'ââ¬Â 'ÃÆ'Ã'ÃââÃÆ'ââââ¬Ã
¡ Then apply +5V to KFLOP.ÃÆ'Ã'Ãâ 'ÃÆ'ââ¬Â 'ÃÆ'Ã'ÃââÃÆ'ââââ¬Ã
¡ The "I'm Alive" LED on SnapAmp should blink continuously.ÃÆ'Ã'Ãâ 'ÃÆ'ââ¬Â 'ÃÆ'Ã'ÃââÃÆ'ââââ¬Ã
¡ If it doesn't the board is bad and you will need to return it for analysis/repair.
> > > > > > > > > Regards
> > > > > > > > > TKÃÆ'Ã'Ãâ 'ÃÆ'ââ¬Â 'ÃÆ'Ã'ÃââÃÆ'ââââ¬Ã
¡ ÃÆ'Ã'Ãâ 'ÃÆ'ââ¬Â 'ÃÆ'Ã'ÃââÃÆ'ââââ¬Ã
> > > > > > > > > Sent: Wednesday, May 16, 2012 3:40 PM
> > > > > > > > > Subject: [DynoMotion] SnapAmp .....No More Function
> > > > > > > > > So I had one axis connected, encoder working, and was playing with the servo tuning most of the morning.
> > > > > > > > > I decided to try to implement a watchdog on pin 83 of Snapamp that would be part of my estop.
> > > > > > > > > After finishing the C code part....i attempted to change the state of the input to see if it would work.
> > > > > > > > > The lights went out on the SnapAmp, and they don't seem like they are coming back.
> > > > > > > > > What did I do?
> > > > > > > > > Can I test the SnapAmp somehow?
Message: 5009 |
Date: 5/20/2012 |
Hi Michael, No it is better to have the Motor Supply on before trying to enable the Axis. If the Motor Supply is not on when you enable the Axis then the servo is likely to detect a small error and make a futile attempt to correct the error which wil result in max output being commanded. Then is the Motor supply is turned on there is likely to be a big jerk. You might have read that the +5V for KFLOP and SnapAmp should be applied before Motor Power. Although not necessary if possible this is the preferred
sequence. The SnapAmp Fans come on automatically at 40C. The Fan.c program was for the now obsolete KMotion Board. Regards TK
DynoMotion@yahoogroups.com Sent: Sunday, May 20, 2012 7:12 PM Subject: [DynoMotion] Re: SnapAmp .....No More Function
Is that correct?
Mike
> Hi Mike,
> Ok...thanks again.
> Mike
> > Hi Mike,
> > ÂÂ
> > For the opto inputs the 470 ohms is internal. Just connect the + terminal to either +5V or +12V and the - terminal to your switch and the other end of the switch to ground.
> > ÂÂ
> > Regarding not being messy: That is hard. The Winford board has a prototype area you might consider using. Otherwise you might find industrial PLC or OPTO22 type modules to do the conversion. But you still may need a serie resistor if they put out +5V (or actually more than 3.5V).
> > ÂÂ
> > ÂÂ
> > Tom,
> > Thanks again,
> > Mike
> > > Hi Mike,
> > > ÂÂÂ
> > > I'm not sure I follow that. But see attached for a possible solution. This takes advantage of the internal pull downs on certain KFLOP pins. The Pull up forms a divider to put 3V on the pin. When the switch opens R2 pulls the pin to 0V. R1 also provides protection against spikes on the +5V bus. The capacitor provides filtering in case of nois spikes picked up in the wiring. To use Pins without
> > > ÂÂÂ
> > > Regards
> > > ÂÂÂ
> > > Tom,
> > > Mike
> > > > Tom,
> > > > Mike
> > > > > Thanks
> > > > > > TK
> > > > > > Thanks,
> > > > > > Mike
> > > > > > > Hi Mike,
> > > > > > > ÃÆ'Æ'‚
> > > > > > > +12V is not required for KFLOP/SnapAmp.ÃÆ'Æ'‚ That supply is just routed through KFLOP to the various connectors to be convieniently available if needed for some custom purpose.
> > > > > > > ÃÆ'Æ'‚
> > > > > > > SnapAmp GPIO inputs are +5VÃÆ'Æ'‚ tolerant so connecting directly to +3.3V should not be a problem.ÃÆ'Æ'‚ But it would be prudent to add a series resistor of several hundred ohms.ÃÆ'Æ'‚ It that case if there was a momentary noise spike to say +7V ( or -2V) it wouldn't cause any damage.ÃÆ'Æ'‚
The GPIO inputs are very high impedence (meg ohms) so a series resistance would still easily drive them.ÃÆ'Æ'‚
> > > > > > > ÃÆ'Æ'‚
> > > > > > > However you would also need a pull down resistor.ÃÆ'Æ'‚ This is because when your switch opens the input would be left floating and would not necessarily return to 0V.ÃÆ'Æ'‚ More likely stray capacitance would keep it at 3.3V so the signal would remain high whether the switch was open or closed.
> > > > > > > ÃÆ'Æ'‚
> > > > > > > ÃÆ'Æ'‚
> > > > > > > Regards
> > > > > > > TK
> > > > > > > ÃÆ'Æ'‚
> > > > > > > ÃÆ'Æ'‚
> > > > > > > Mike
> > > > > > > > Hi Michael,
> > > > > > > > ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ÃÆ'Æ'‚
> > > > > > > > 3.3V shouldÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ÃÆ'Æ'‚ not cause any damage.ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ÃÆ'Æ'‚ TheÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ÃÆ'Æ'‚ next pin over on JP7 is 12V though whichÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ÃÆ'Æ'‚ wouldÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ÃÆ'Æ'‚ cause damage.ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ÃÆ'Æ'‚ Are you applying 12V to KFLOP?
> > > > > > > > send to:
> > > > > > > > Dynomotion
> > > > > > > > 3532 Adamsville Ave
> > > > > > > > Calabasas, CA 91302
> > > > > > > > TK
> > > > > > > > ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ÃÆ'Æ'‚ ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ÃÆ'Æ'‚
> > > > > > > > Mike
> > > > > > > > > Hi Michael,
> > > > > > > > > ÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'¢ÃÆ'¢â€šÂ¬ÃÆ'…¡ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ÃÆ'Æ'‚
> > > > > > > > > To Test you should remove all connections from both boards.ÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'¢ÃÆ'¢â€šÂ¬ÃÆ'…¡ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ÃÆ'Æ'‚ Leave only the 16 pin ribbon connection between KFLOP and the SnapAmp.ÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'¢ÃÆ'¢â€šÂ¬ÃÆ'…¡ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ÃÆ'Æ'‚ Then apply +5V to KFLOP.ÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'¢ÃÆ'¢â€šÂ¬ÃÆ'…¡ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ÃÆ'Æ'‚ The "I'm Alive" LED on SnapAmp should blink continuously.ÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'¢ÃÆ'¢â€šÂ¬ÃÆ'…¡ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ÃÆ'Æ'‚ If it doesn't the board is bad and you will need to return it for analysis/repair.
> > > > > > > > > Regards
> > > > > > > > > TKÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'¢ÃÆ'¢â€šÂ¬ÃÆ'…¡ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ÃÆ'Æ'‚ ÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'¢ÃÆ'¢â€šÂ¬ÃÆ'…¡ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ÃÆ'Æ'‚
> > > > > > > > > What did I do?
Message: 5011 |
Date: 5/21/2012 |
OK....thats easier to deal with for me. :-)
Mike
> Hi Michael,
> You might have read that the +5V for KFLOP and SnapAmp should be applied before Motor Power. Although not necessary if possible this is the preferred sequence.
> Thanks,
> Is that correct?
> Mike
> > Hi Mike,
> > Yes usually there is a "for" loop at the end of your main function.ÃÂ The loop has a set of curly brackets after it.ÃÂ Everything in the curly brackets gets executed every time around the loop.ÃÂ So if there is N operations that you want to have continuously performed then put them all in the loop.
> > ÃÂ
> > Ok...thanks again.
> > Mike
> > > Hi Mike,
> > > ÃâÃÂ
> > > For the opto inputs the 470 ohms is internal.ÃâàJust connect the + terminal to either +5V or +12V and the - terminal to your switch and the other end of the switch to ground.
> > > ÃâÃÂ
> > > Regarding not being messy: That is hard.ÃâàThe Winford board has a prototype area you might consider using.ÃâàOtherwise you might find industrial PLC or OPTO22 type modules to do the conversion.ÃâàBut you still may need a serie resistor if they put out +5V (or actually more thanÃâà3.5V).
> > > ÃâÃÂ
> > > Regards
> > > ÃâÃÂ
> > > Tom,
> > > Thanks again,
> > > Mike
> > > > Hi Mike,
> > > > ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > I'm not sure I follow that.ÃÆ'ââ¬Å¡ÃâàBut see attached for a possible solution.ÃÆ'ââ¬Å¡ÃâàThis takes advantage of the internal pull downs on certain KFLOP pins.ÃÆ'ââ¬Å¡ÃâàThe Pull up forms a divider to put 3V on the pin.ÃÆ'ââ¬Å¡ÃâàWhen the switch opens R2 pulls the pin to 0V.ÃÆ'ââ¬Å¡ÃâàR1 also provides protection against spikes on the +5V bus.ÃÆ'ââ¬Å¡ÃâàThe capacitor provides filtering in case of nois spikes picked up in the wiring.ÃÆ'ââ¬Å¡ÃâàTo use Pins without internal pull downs add a pull down externally.
> > > > ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > Regards
> > > > TK
> > > > ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > Tom,
> > > > Mike
> > > > > Tom,
> > > > > Mike
> > > > > > Thanks
> > > > > > > TK
> > > > > > > Thanks,
> > > > > > > Mike
> > > > > > > > Hi Mike,
> > > > > > > > +12V is not required for KFLOP/SnapAmp.ÃÆ'Ã'Ãâ 'ÃÆ'ââââ¬Å¡Ã¬Ãâ¦Ã¡ That supply is just routed through KFLOP to the various connectors to be convieniently available if needed for some custom purpose.
> > > > > > > > SnapAmp GPIO inputs are +5VÃÆ'Ã'Ãâ 'ÃÆ'ââââ¬Å¡Ã¬Ãâ¦Ã¡ tolerant so connecting directly to +3.3V should not be a problem.ÃÆ'Ã'Ãâ 'ÃÆ'ââââ¬Å¡Ã¬Ãâ¦Ã¡ But it would be prudent to add a series resistor of several hundred ohms.ÃÆ'Ã'Ãâ 'ÃÆ'ââââ¬Å¡Ã¬Ãâ¦Ã¡ It that case if there was a momentary noise spike to say +7V ( or -2V) it wouldn't cause any damage.ÃÆ'Ã'Ãâ 'ÃÆ'ââââ¬Å¡Ã¬Ãâ¦Ã¡ The GPIO inputs are very high impedence (meg ohms) so a series resistance would still easily drive them.ÃÆ'Ã'Ãâ 'ÃÆ'ââââ¬Å¡Ã¬Ãâ¦Ã¡
> > > > > > > > However you would also need a pull down resistor.ÃÆ'Ã'Ãâ 'ÃÆ'ââââ¬Å¡Ã¬Ãâ¦Ã¡ This is because when your switch opens the input would be left floating and would not necessarily return to 0V.ÃÆ'Ã'Ãâ 'ÃÆ'ââââ¬Å¡Ã¬Ãâ¦Ã¡ More likely stray capacitance would keep it at 3.3V so the signal would remain high whether the switch was open or closed.
> > > > > > > > Regards
> > > > > > > > TK
> > > > > > > > Mike
> > > > > > > > > Hi Michael,
> > > > > > > > > 3.3V shouldÃÆ'Ã'Ãâ 'ÃÆ'ââ¬Â 'ÃÆ'Ã'ÃââÃÆ'ââââ¬Ã
¡ÃâìÃÆ'ââ¬Â¦ÃâáÃÆ'Ã'Ãâ 'ÃÆ'ââââ¬Å¡Ã¬Ãâ¦Ã¡ not cause any damage.ÃÆ'Ã'Ãâ 'ÃÆ'ââ¬Â 'ÃÆ'Ã'ÃââÃÆ'ââââ¬Ã
¡ÃâìÃÆ'ââ¬Â¦ÃâáÃÆ'Ã'Ãâ 'ÃÆ'ââââ¬Å¡Ã¬Ãâ¦Ã¡ TheÃÆ'Ã'Ãâ 'ÃÆ'ââ¬Â 'ÃÆ'Ã'ÃââÃÆ'ââââ¬Ã
¡ÃâìÃÆ'ââ¬Â¦ÃâáÃÆ'Ã'Ãâ 'ÃÆ'ââââ¬Å¡Ã¬Ãâ¦Ã¡ next pin over on JP7 is 12V though whichÃÆ'Ã'Ãâ 'ÃÆ'ââ¬Â 'ÃÆ'Ã'ÃââÃÆ'ââââ¬Ã
¡ÃâìÃÆ'ââ¬Â¦ÃâáÃÆ'Ã'Ãâ 'ÃÆ'ââââ¬Å¡Ã¬Ãâ¦Ã¡ wouldÃÆ'Ã'Ãâ 'ÃÆ'ââ¬Â 'ÃÆ'Ã'ÃââÃÆ'ââââ¬Ã
¡ÃâìÃÆ'ââ¬Â¦ÃâáÃÆ'Ã'Ãâ 'ÃÆ'ââââ¬Å¡Ã¬Ãâ¦Ã¡ cause damage.ÃÆ'Ã'Ãâ 'ÃÆ'ââ¬Â 'ÃÆ'Ã'ÃââÃÆ'ââââ¬Ã
¡ÃâìÃÆ'ââ¬Â¦ÃâáÃÆ'Ã'Ãâ 'ÃÆ'ââââ¬Å¡Ã¬Ãâ¦Ã¡ Are you applying 12V to
> KFLOP?
> > > > > > > > > send to:
> > > > > > > > > Dynomotion
> > > > > > > > > 3532 Adamsville Ave
> > > > > > > > > Calabasas, CA 91302
> > > > > > > > > TK
¡ÃâìÃÆ'ââ¬Â¦ÃâáÃÆ'Ã'Ãâ 'ÃÆ'ââââ¬Å¡Ã¬Ãâ¦Ã¡ ÃÆ'Ã'Ãâ 'ÃÆ'ââ¬Â 'ÃÆ'Ã'ÃââÃÆ'ââââ¬Ã
> > > > > > > > > Mike
> > > > > > > > > > Hi Michael,
> > > > > > > > > > ÃÆ'Ã'Ãâ 'ÃÆ'ââ¬Â 'ÃÆ'Ã'âââ¬Ã 'ÃÆ'Ã'Ãâ 'ÃÆ'ââ¬Å¡ÃââÃÆ'Ã'ÃââÃÆ'ââââ¬Å¡Ã¬Ãâ¦Ã¡ÃÆ'ââ¬Å¡ÃâìÃÆ'Ã'âââ¬Ã¦ÃÆ'ââ¬Å¡ÃâáÃÆ'Ã'Ãâ 'ÃÆ'ââ¬Â 'ÃÆ'Ã'ÃââÃÆ'ââââ¬Ã
> > > > > > > > > > To Test you should remove all connections from both boards.ÃÆ'Ã'Ãâ 'ÃÆ'ââ¬Â 'ÃÆ'Ã'âââ¬Ã 'ÃÆ'Ã'Ãâ 'ÃÆ'ââ¬Å¡ÃââÃÆ'Ã'ÃââÃÆ'ââââ¬Å¡Ã¬Ãâ¦Ã¡ÃÆ'ââ¬Å¡ÃâìÃÆ'Ã'âââ¬Ã¦ÃÆ'ââ¬Å¡ÃâáÃÆ'Ã'Ãâ 'ÃÆ'ââ¬Â 'ÃÆ'Ã'ÃââÃÆ'ââââ¬Ã
¡ÃâìÃÆ'ââ¬Â¦ÃâáÃÆ'Ã'Ãâ 'ÃÆ'ââââ¬Å¡Ã¬Ãâ¦Ã¡ Leave only the 16 pin ribbon connection between KFLOP and the SnapAmp.ÃÆ'Ã'Ãâ 'ÃÆ'ââ¬Â 'ÃÆ'Ã'âââ¬Ã 'ÃÆ'Ã'Ãâ 'ÃÆ'ââ¬Å¡ÃââÃÆ'Ã'ÃââÃÆ'ââââ¬Å¡Ã¬Ãâ¦Ã¡ÃÆ'ââ¬Å¡ÃâìÃÆ'Ã'âââ¬Ã¦ÃÆ'ââ¬Å¡ÃâáÃÆ'Ã'Ãâ 'ÃÆ'ââ¬Â 'ÃÆ'Ã'ÃââÃÆ'ââââ¬Ã
¡ÃâìÃÆ'ââ¬Â¦ÃâáÃÆ'Ã'Ãâ 'ÃÆ'ââââ¬Å¡Ã¬Ãâ¦Ã¡ Then apply +5V to
> KFLOP.ÃÆ'Ã'Ãâ 'ÃÆ'ââ¬Â 'ÃÆ'Ã'âââ¬Ã 'ÃÆ'Ã'Ãâ 'ÃÆ'ââ¬Å¡ÃââÃÆ'Ã'ÃââÃÆ'ââââ¬Å¡Ã¬Ãâ¦Ã¡ÃÆ'ââ¬Å¡ÃâìÃÆ'Ã'âââ¬Ã¦ÃÆ'ââ¬Å¡ÃâáÃÆ'Ã'Ãâ 'ÃÆ'ââ¬Â 'ÃÆ'Ã'ÃââÃÆ'ââââ¬Ã
¡ÃâìÃÆ'ââ¬Â¦ÃâáÃÆ'Ã'Ãâ 'ÃÆ'ââââ¬Å¡Ã¬Ãâ¦Ã¡ The "I'm Alive" LED on SnapAmp should blink continuously.ÃÆ'Ã'Ãâ 'ÃÆ'ââ¬Â 'ÃÆ'Ã'âââ¬Ã 'ÃÆ'Ã'Ãâ 'ÃÆ'ââ¬Å¡ÃââÃÆ'Ã'ÃââÃÆ'ââââ¬Å¡Ã¬Ãâ¦Ã¡ÃÆ'ââ¬Å¡ÃâìÃÆ'Ã'âââ¬Ã¦ÃÆ'ââ¬Å¡ÃâáÃÆ'Ã'Ãâ 'ÃÆ'ââ¬Â 'ÃÆ'Ã'ÃââÃÆ'ââââ¬Ã
¡ÃâìÃÆ'ââ¬Â¦ÃâáÃÆ'Ã'Ãâ 'ÃÆ'ââââ¬Å¡Ã¬Ãâ¦Ã¡ If it doesn't the board is bad and you will need to return it for analysis/repair.
> > > > > > > > > > Regards
> > > > > > > > > > TKÃÆ'Ã'Ãâ 'ÃÆ'ââ¬Â 'ÃÆ'Ã'âââ¬Ã 'ÃÆ'Ã'Ãâ 'ÃÆ'ââ¬Å¡ÃââÃÆ'Ã'ÃââÃÆ'ââââ¬Å¡Ã¬Ãâ¦Ã¡ÃÆ'ââ¬Å¡ÃâìÃÆ'Ã'âââ¬Ã¦ÃÆ'ââ¬Å¡ÃâáÃÆ'Ã'Ãâ 'ÃÆ'ââ¬Â 'ÃÆ'Ã'ÃââÃÆ'ââââ¬Ã
¡ÃâìÃÆ'ââ¬Â¦ÃâáÃÆ'Ã'Ãâ 'ÃÆ'ââââ¬Å¡Ã¬Ãâ¦Ã¡ ÃÆ'Ã'Ãâ 'ÃÆ'ââ¬Â 'ÃÆ'Ã'âââ¬Ã 'ÃÆ'Ã'Ãâ 'ÃÆ'ââ¬Å¡ÃââÃÆ'Ã'ÃââÃÆ'ââââ¬Å¡Ã¬Ãâ¦Ã¡ÃÆ'ââ¬Å¡ÃâìÃÆ'Ã'âââ¬Ã¦ÃÆ'ââ¬Å¡ÃâáÃÆ'Ã'Ãâ 'ÃÆ'ââ¬Â 'ÃÆ'Ã'ÃââÃÆ'ââââ¬Ã
> > > > > > > > > > What did I do?
Message: 4973 |
Date: 5/16/2012 |
Subject: SnapAmp .....No More Function |
What did I do?
Message: 4974 |
Date: 5/16/2012 |
I can no longer toggle output bits from the console, either.
I can set bit direction.....but nothing else.
Mike
--- In DynoMotion@yahoogroups.com, "michaelthomasn" <michaelniksch@...> wrote:
> What did I do?
Message: 4975 |
Date: 5/16/2012 |
Hi Michael,
To Test you should remove all connections from both boards. Leave only the 16 pin ribbon connection between KFLOP and the SnapAmp. Then apply +5V to KFLOP. The "I'm Alive" LED on SnapAmp should blink continuously. If it doesn't the board is bad and you will need to return it for analysis/repair.
Message: 4976 |
Date: 5/16/2012 |
Mike
> Hi Michael,
> TKÂ Â
> What did I do?
Message: 4977 |
Date: 5/16/2012 |
Hi Michael,
3.3V should not cause any damage. The next pin over on JP7 is 12V though which would cause damage. Are you applying 12V to KFLOP?
send to:
3532 Adamsville Ave
Calabasas, CA 91302
Message: 4978 |
Date: 5/16/2012 |
Mike
> Hi Michael,
> send to:
> Dynomotion
> 3532 Adamsville Ave
> Calabasas, CA 91302
> Â Â
> Mike
> > Hi Michael,
> > ÃÂ
> > ÃÂ
> > To Test you should remove all connections from both boards.ÃÂ Leave only the 16 pin ribbon connection between KFLOP and the SnapAmp.ÃÂ Then apply +5V to KFLOP.ÃÂ The "I'm Alive" LED on SnapAmp should blink continuously.ÃÂ If it doesn't the board is bad and you will need to return it for analysis/repair.
> > ÃÂ
> > TKÃÂ ÃÂ
> > ÃÂ
> > What did I do?
Message: 4979 |
Date: 5/16/2012 |
Hi Mike,
+12V is not required for KFLOP/SnapAmp. That supply is just routed through KFLOP to the various connectors to be convieniently available if needed for some custom purpose.
SnapAmp GPIO inputs are +5V tolerant so connecting directly to +3.3V should not be a problem. But it would be prudent to add a series resistor of several hundred ohms. It that case if there was a momentary noise spike to say +7V ( or -2V) it wouldn't cause any damage. The GPIO inputs are very high impedence (meg ohms) so a series resistance would still easily drive them.
However you would also need a pull down resistor. This is because when your switch opens the input would be left floating and would not necessarily return to 0V. More likely stray capacitance would keep it at 3.3V so the signal would remain high whether the switch was open or closed.
Message: 4980 |
Date: 5/16/2012 |
Mike
> Hi Mike,
> SnapAmp GPIO inputs are +5V tolerant so connecting directly to +3.3V should not be a problem. But it would be prudent to add a series resistor of several hundred ohms. It that case if there was a momentary noise spike to say +7V ( or -2V) it wouldn't cause any damage. The GPIO inputs are very high impedence (meg ohms) so a series resistance would still easily drive them.Â
> Mike
> > Hi Michael,
> > ÃÂ
> > 3.3V shouldÃÂ not cause any damage.ÃÂ TheÃÂ next pin over on JP7 is 12V though whichÃÂ wouldÃÂ cause damage.ÃÂ Are you applying 12V to KFLOP?
> > ÃÂ
> > send to:
> > ÃÂ
> > Dynomotion
> > 3532 Adamsville Ave
> > Calabasas, CA 91302
> > ÃÂ
> > ÃÂ
> > ÃÂ ÃÂ
> > ÃÂ
> > Mike
> > > Hi Michael,
> > > ÃâÃÂ
> > > ÃâÃÂ
> > > To Test you should remove all connections from both boards.ÃâàLeave only the 16 pin ribbon connection between KFLOP and the SnapAmp.ÃâàThen apply +5V to KFLOP.ÃâàThe "I'm Alive" LED on SnapAmp should blink continuously.ÃâàIf it doesn't the board is bad and you will need to return it for analysis/repair.
> > > ÃâÃÂ
> > > Regards
> > > TKÃâàÃâÃÂ
> > > ÃâÃÂ
> > > What did I do?
Message: 4981 |
Date: 5/16/2012 |
Message: 4982 |
Date: 5/16/2012 |
Message: 4984 |
Date: 5/17/2012 |
Mike
--- In DynoMotion@yahoogroups.com, Michael Niksch <michaelniksch@...> wrote:
> Thanks
> > Thanks,
> > Mike
> > > Hi Mike,
> > > Ã
> > > +12V is not required for KFLOP/SnapAmp.Ã That supply is just routed through KFLOP to the various connectors to be convieniently available if needed for some custom purpose.
> > > Ã
> > > SnapAmp GPIO inputs are +5VÃ tolerant so connecting directly to +3.3V should not be a problem.Ã But it would be prudent to add a series resistor of several hundred ohms.Ã It that case if there was a momentary noise spike to say +7V ( or -2V) it wouldn't cause any damage.Ã The GPIO inputs are very high impedence (meg ohms) so a series resistance would still easily drive them.Ã
> > > Ã
> > > However you would also need a pull down resistor.Ã This is because when your switch opens the input would be left floating and would not necessarily return to 0V.Ã More likely stray capacitance would keep it at 3.3V so the signal would remain high whether the switch was open or closed.
> > > Ã
> > > Ã
> > > Regards
> > > Ã
> > > Ã
> > > Mike
> > > > Hi Michael,
> > > > ÃâÃ
> > > > 3.3V shouldÃâà not cause any damage.Ãâà TheÃâà next pin over on JP7 is 12V though whichÃâà wouldÃâà cause damage.Ãâà Are you applying 12V to KFLOP?
> > > > ÃâÃ
> > > > send to:
> > > > ÃâÃ
> > > > Dynomotion
> > > > 3532 Adamsville Ave
> > > > Calabasas, CA 91302
> > > > ÃâÃ
> > > > ÃâÃ
> > > > TK
> > > > Ãâà ÃâÃ
> > > > ÃâÃ
> > > > Mike
> > > > > Hi Michael,
> > > > > ÃÆ'ââ¬Å¡ÃâÃ
> > > > > ÃÆ'ââ¬Å¡ÃâÃ
> > > > > To Test you should remove all connections from both boards.ÃÆ'ââ¬Å¡Ãâà Leave only the 16 pin ribbon connection between KFLOP and the SnapAmp.ÃÆ'ââ¬Å¡Ãâà Then apply +5V to KFLOP.ÃÆ'ââ¬Å¡Ãâà The "I'm Alive" LED on SnapAmp should blink continuously.ÃÆ'ââ¬Å¡Ãâà If it doesn't the board is bad and you will need to return it for analysis/repair.
> > > > > ÃÆ'ââ¬Å¡ÃâÃ
> > > > > Regards
> > > > > TKÃÆ'ââ¬Å¡Ãâà ÃÆ'ââ¬Å¡ÃâÃ
> > > > > ÃÆ'ââ¬Å¡ÃâÃ
> > > > > What did I do?
Message: 4985 |
Date: 5/17/2012 |
Mike
> Tom,
> Mike
> > Thanks
> > > Thanks,
> > > Mike
> > > > Hi Mike,
> > > > Ã
> > > > Ã
> > > > Ã
> > > > Ã
> > > > Ã
> > > > Regards
> > > > TK
> > > > Ã
> > > > Ã
> > > > Mike
> > > > > Hi Michael,
> > > > > ÃâÃ
> > > > > ÃâÃ
> > > > > send to:
> > > > > ÃâÃ
> > > > > Dynomotion
> > > > > 3532 Adamsville Ave
> > > > > Calabasas, CA 91302
> > > > > ÃâÃ
> > > > > ÃâÃ
> > > > > TK
> > > > > Ãâà ÃâÃ
> > > > > ÃâÃ
> > > > > Mike
> > > > > > Hi Michael,
> > > > > > ÃÆ'ââ¬Å¡ÃâÃ
> > > > > > ÃÆ'ââ¬Å¡ÃâÃ
> > > > > > ÃÆ'ââ¬Å¡ÃâÃ
> > > > > > Regards
> > > > > > ÃÆ'ââ¬Å¡ÃâÃ
> > > > > > What did I do?
Message: 4987 |
Date: 5/17/2012 |
Hi Mike,
I'm not sure I follow that. But see attached for a possible solution. This takes advantage of the internal pull downs on certain KFLOP pins. The Pull up forms a divider to put 3V on the pin. When the switch opens R2 pulls the pin to 0V. R1 also provides protection against spikes on the +5V bus. The capacitor provides filtering in case of nois spikes picked up in the wiring. To use Pins without internal pull downs add a pull down externally.
Message: 4991 |
Date: 5/18/2012 |
Thanks again,
Mike
> Hi Mike,
> Tom,
> Mike
> > Tom,
> > Mike
> > > Thanks
> > > > TK
> > > > Thanks,
> > > > Mike
> > > > > Hi Mike,
> > > > > Ãâ
> > > > > +12V is not required for KFLOP/SnapAmp.Ãâ That supply is just routed through KFLOP to the various connectors to be convieniently available if needed for some custom purpose.
> > > > > Ãâ
> > > > > SnapAmp GPIO inputs are +5VÃâ tolerant so connecting directly to +3.3V should not be a problem.Ãâ But it would be prudent to add a series resistor of several hundred ohms.Ãâ It that case if there was a momentary noise spike to say +7V ( or -2V) it wouldn't cause any damage.Ãâ The GPIO inputs are very high impedence (meg ohms) so a series resistance would still easily drive them.Ãâ
> > > > > Ãâ
> > > > > However you would also need a pull down resistor.Ãâ This is because when your switch opens the input would be left floating and would not necessarily return to 0V.Ãâ More likely stray capacitance would keep it at 3.3V so the signal would remain high whether the switch was open or closed.
> > > > > Ãâ
> > > > > Ãâ
> > > > > Regards
> > > > > TK
> > > > > Ãâ
> > > > > Ãâ
> > > > > Mike
> > > > > > Hi Michael,
> > > > > > ÃÆ'ââ¬Å¡Ãâ
> > > > > > 3.3V shouldÃÆ'ââ¬Å¡Ãâ not cause any damage.ÃÆ'ââ¬Å¡Ãâ TheÃÆ'ââ¬Å¡Ãâ next pin over on JP7 is 12V though whichÃÆ'ââ¬Å¡Ãâ wouldÃÆ'ââ¬Å¡Ãâ cause damage.ÃÆ'ââ¬Å¡Ãâ Are you applying 12V to KFLOP?
> > > > > > ÃÆ'ââ¬Å¡Ãâ
> > > > > > send to:
> > > > > > ÃÆ'ââ¬Å¡Ãâ
> > > > > > Dynomotion
> > > > > > 3532 Adamsville Ave
> > > > > > Calabasas, CA 91302
> > > > > > ÃÆ'ââ¬Å¡Ãâ
> > > > > > ÃÆ'ââ¬Å¡Ãâ
> > > > > > TK
> > > > > > ÃÆ'ââ¬Å¡Ãâ ÃÆ'ââ¬Å¡Ãâ
> > > > > > ÃÆ'ââ¬Å¡Ãâ
> > > > > > Mike
> > > > > > > Hi Michael,
> > > > > > > ÃÆ'Ã'âââ¬Ã
¡ÃÆ'ââ¬Å¡Ãâ
> > > > > > > ÃÆ'Ã'âââ¬Ã
¡ÃÆ'ââ¬Å¡Ãâ
> > > > > > > To Test you should remove all connections from both boards.ÃÆ'Ã'âââ¬Ã
¡ÃÆ'ââ¬Å¡Ãâ Leave only the 16 pin ribbon connection between KFLOP and the SnapAmp.ÃÆ'Ã'âââ¬Ã
¡ÃÆ'ââ¬Å¡Ãâ Then apply +5V to KFLOP.ÃÆ'Ã'âââ¬Ã
¡ÃÆ'ââ¬Å¡Ãâ The "I'm Alive" LED on SnapAmp should blink continuously.ÃÆ'Ã'âââ¬Ã
¡ÃÆ'ââ¬Å¡Ãâ If it doesn't the board is bad and you will need to return it for analysis/repair.
> > > > > > > ÃÆ'Ã'âââ¬Ã
¡ÃÆ'ââ¬Å¡Ãâ
> > > > > > > Regards
> > > > > > > TKÃÆ'Ã'âââ¬Ã
¡ÃÆ'ââ¬Å¡Ãâ ÃÆ'Ã'âââ¬Ã
¡ÃÆ'ââ¬Å¡Ãâ
> > > > > > > ÃÆ'Ã'âââ¬Ã
¡ÃÆ'ââ¬Å¡Ãâ
> > > > > > > What did I do?
Message: 4992 |
Date: 5/18/2012 |
Hi Mike, For the opto inputs the 470 ohms is internal. Just connect the + terminal to either +5V or +12V and the - terminal to your switch and the other end of the switch to ground. Regarding not being messy: That is hard. The Winford board has a prototype area you might consider using. Otherwise you might find industrial PLC or OPTO22 type modules to do the conversion. But you still may need a serie resistor if they put out +5V (or actually more than 3.5V). Regards TK
From: michaelthomasn <michaelniksch@...> To: DynoMotion@yahoogroups.com Sent: Friday, May 18, 2012 7:34 AM Subject: [DynoMotion] Re: SnapAmp .....No More Function
Thanks again,
Mike
> Hi Mike,
> Tom,
> Mike
> > Tom,
> > Mike
> > > Thanks
> > > > TK
> > > > Thanks,
> > > > Mike
> > > > > Hi Mike,
> > > > > Â
> > > > > Â
> > > > > Â
> > > > > Â
> > > > > Â
> > > > > Regards
> > > > > TK
> > > > > Â
> > > > > Â
> > > > > Mike
> > > > > > Hi Michael,
> > > > > > ÃÆ'‚Â
> > > > > > 3.3V shouldÃÆ'‚Â not cause any damage.ÃÆ'‚Â TheÃÆ'‚Â next pin over on JP7 is 12V though whichÃÆ'‚Â wouldÃÆ'‚Â cause damage.ÃÆ'‚Â Are you applying 12V to KFLOP?
> > > > > > ÃÆ'‚Â
> > > > > > send to:
> > > > > > ÃÆ'‚Â
> > > > > > Dynomotion
> > > > > > 3532 Adamsville Ave
> > > > > > Calabasas, CA 91302
> > > > > > ÃÆ'‚Â
> > > > > > ÃÆ'‚Â
> > > > > > TK
> > > > > > ÃÆ'‚Â ÃÆ'‚Â
> > > > > > ÃÆ'‚Â
> > > > > > Mike
> > > > > > > Hi Michael,
> > > > > > > ÃÆ'Æ'‚ÃÆ'‚Â
> > > > > > > ÃÆ'Æ'‚ÃÆ'‚Â
> > > > > > > To Test you should remove all connections from both boards.ÃÆ'Æ'‚ÃÆ'‚Â Leave only the 16 pin ribbon connection between KFLOP and the SnapAmp.ÃÆ'Æ'‚ÃÆ'‚Â Then apply +5V to KFLOP.ÃÆ'Æ'‚ÃÆ'‚Â The "I'm Alive" LED on SnapAmp should blink continuously.ÃÆ'Æ'‚ÃÆ'‚Â If it doesn't the board is bad and you will need to return it for analysis/repair.
> > > > > > > ÃÆ'Æ'‚ÃÆ'‚Â
> > > > > > > Regards
> > > > > > > TKÃÆ'Æ'‚ÃÆ'‚Â ÃÆ'Æ'‚ÃÆ'‚Â
> > > > > > > ÃÆ'Æ'‚ÃÆ'‚Â
> > > > > > > What did I do?
